Make advanced camera settings use the unit settings
Feature request: the AdvancedCameraSettings (ACS) should use the units you set in the model info-units section.
At the moment it uses inches as units, even when the project is set to decimal and mm units. So when working with the ACS panel, and you’re fine-tuning camera positions, you have to manually recalculate all the values.
