Suddenly, with every model, even a fresh new model, every component, every time you edit, even if you close and re-edit, the main axes disappear and only the component’s axes appear. Drawing from the main axes is not possible when editing any component so you can’t for example draw concentric circles from the origin. Even if you draw some tape measure lines at the main axes, those lines stop being a magnetic point when you edit any component in any project. Sketchup can barely be used because of this.
See DropBox screen captures 1, 2, 3, 4. These very clearly illustrate the problem and why SketchUp can’t be used any more. Remember this problem happens in every project and every component. Axes setting has always been turned on. Flushed cookies and temp files.
Please, I know about resetting the axes in a component. That only works at the moment of editing and you have to do it again when you close that component edit it again. If you have say 50 components, you have to do this for every one, every time you edit, every component, every project… Even having a single component is extremely difficult when the main axis disappears when editing. It is not possible to use Sketchup this way.
Dead simple illustrations to reproduce. 1, 2, 3, 4
Thanks!
