Machining / Components
Hi World
     I have been trying to try and make components with cut openings. My issue is I wish to make opening in hollow sections (either 2 faces or 4 faces) and also work in a group. I see there is an extension called Double Cut. I also noticed that even and open cut doesn't work in a plugin called Metal fab from DBS.
does any one have any ideas , or know what i’m trying to create.
Thanking you all in advance
Please make your post into straight tex, and give us a clearer idea of what you are trying to create.
I don’t. better show some photos of what you’re trying to achieve.
Imagine having a lock. I create a lock and when inserting it to a hollow section/ group, I would to have made cut options that it has the cuts for the lock and key barrel.
Hole-cutting components only cut one face.
