无法使用它(按钮是黑色的) 更换2021至2022版本都没办法解决
Translate:
There is no way to use (send to layout button) on mac apple notebooks
Can’t use it (the button is black) Changing the 2021 to 2022 version doesn’t fix it
The send to Layout button in the large tool set works fine on Mac. How did you install SketchUp onto your mac? SketchUp needs to be able to find the Layout program to sent to. The SketchUp Folder for a given year with the SketchUp, Layout, and Style Builder Apps all in it needs to be in your systems application folder.
翻译,使用谷歌翻译
大型工具集中的发送到布局按钮在 Mac 上运行良好。 您是如何将 SketchUp 安装到您的 Mac 上的? SketchUp 需要能够找到要发送到的 Layout 程序。 包含 SketchUp、Layout 和 Style Builder 应用程序的给定年份的 SketchUp 文件夹需要位于您的系统应用程序文件夹中。
I will try to reinstall it. If there is no solution, I will leave you a message. Thank you
I have tried to reinstall it, but it still cannot be used to send to layout
Have you saved the sketchup file first?
Yes, my version is also the latest version, I tried everything, but failed to solve the problem
