… I have plenty of storage. I tried deleting the app cache.
I don’t really know what other options I have at my disposal. The application crashes when I try to open the file I’m trying to show to my client.
hello, low memory could be related to the available RAM on your quest device, my guess is that the model you are trying to load is too heavy. Are you sure it is optimized ? did you purge any unnecessary element from it ? tried to run cleanup3 extension ?
I have not done that. How do you recommend optimizing? Is it as simple as running it through a program? Sorry, I’m a noob.
Has anyone found a solution? Running into a similar problem and have run cleanup3 and purged unnecessary elements.
