Losing fill colors from sketchup to layout
I have 2 simple fills in part of my sketchup model with no textures.
As I open in layout… there are no fills unless I use raster, even hybrid will not show the fills? Is there a setting somewhere I have turned on? I don’t mind sharing the file privately if need be.
I had a section cut that I saved as a group, then saved the group as a “new 2d floorplan”.
I deleted the show section cut, but no go… hopefully this makes sense.
Thanks Tim
Send me the file if you want. I’ll look at it.
Got your file. The problem stems from your choice not to save the Style with the scene.
I updated the scene to save the style and other properties and then updated the LO file. Now the file colors show when the viewport is rendered as Vector or Hybrid.
It’s them little things! Thanks so much.
Indeed it is! And you’re quite welcome.
