Hi all,
I’d like to share an extension I’ve been building: Lookover. It reviews your SketchUp model and lists what’s wrong with it, catching issues before the model goes to a client or into LayOut.
I built this after one too many “how did I miss that?” moments: a bed floating off the floor in a client walkthrough, or a last-minute change that quietly broke the stairs. You’ve stared at the model so long you can’t see it anymore. Lookover gives it a fresh look before anyone else does.
It does the usual checks you’d get from the other checking plugins (reversed faces, doubled geometry, copies that should be components, unused materials and tags). The part I’m most excited about is the review on top: an AI looks the model over from several angles and measures things, the way a colleague would before you send it. It catches things a fixed rule can’t:
- A bed floating 5.5 in above the upstairs floor while its two copies sit on it
- A back door shorter than the person standing next to it
- A front window drawn onto solid wall: an outline, but no opening and no glass
- Deck stairs with even 6.4 in risers, then a 10 in step at the top
- A deck 4 ft off the ground with no railing on one side
- One sofa left untagged, so hiding “Furniture” for a LayOut view leaves it behind
Add a note before you start (“this is going into LayOut”, “check the stairs”) and it looks harder at that.
Each finding says what’s wrong, where it is, and what it costs you if you leave it. Where there’s a clear answer, Fix it does the work. Your model only changes when you click it, and every fix is one undo step.
Details
- SketchUp 2024 or newer, Windows and macOS
- Free for 2 reviews a month; Pro is $19/month for 30
- What gets sent to the AI checker: screenshots of the model, plus details about its groups and components (names, sizes, positions, tags, materials). Never the .skp file itself. Nothing is kept after the review, and none of it is used to train AI.
Download: https://lookoverreview.com
I’ve tested it on about 50 models so far: houses, offices, kitchens, decks, parks, furniture, shop jigs, even a theater. But I’d love to see what it does with yours. Run it on a real model and tell me which findings were spot on, and which were wrong or useless. I’ll post fixes and updates in this thread.
Myles
