LO allows you to use a shape to select a region of a window using the pie-cutter principle. Very handy. However, there are times when you want it to operate in reverse. Instead of retaining the section of window inside the shape, you want it to retain the section outside. You might want a window on top of another and for it to cut a piece out of the window underneath to avoid visual conflict, for example. There are long-winded workarounds that enable you to do this but I imagine a simple moderator would allow reversal of the standard operation and so make the whole thing a lot faster.
