I started doing some digging into the Ruby API in hopes of writing extensions related to woodworking, and while experimenting around forming the geometry of some joints (by intersecting groups) I hit this error:
> result = group_a.intersect(group_b)
Error: #<ArgumentError: 'intersect' is a Pro only feature.>
I can understand having a set of methods that only function under Pro, but I can’t find them documented anywhere. Looking at the docs for Group#intersect
, I don’t see anything about it being license restricted.
It seems like a real roadblock to doing any development that might be used in a non-Pro setting if the only way to find restricted features is to exercise them and note the failure.
Does anyone know of a place where the list of Pro-only methods is documented?
Cursory Pro Only list of API methods and classes.
Since the boolean “Solid Tools” is Pro Only, it’s API methods are also:
intersect()
outer_shell()
split()
subtract()
trim()
union()
model.import()
will ignore all Pro Only filetypes on Make.
model.export()
model.classifications()
Classifications
class
ClassificationSchema
class
Any action string (or command ID integer) that would fire a Pro Only feature via:
Sketchup::send_action()
@DanRathbun - thanks for that, definitely a helpful start.
Interestingly I found that while I can’t call Group#intersect
, I was able to run the intersection via Entities#intersect_with
, which looked like:
def draw_block(side_length, height)
group = Sketchup.active_model.entities.add_group
starter_face = group.entities.add_face(
[0,0,0], [side_length,0,0],
[side_length,side_length,0], [0,side_length,0]
).pushpull( -height )
return group
end
group_a = draw_block(10, 4)
group_b = draw_block(20, 1)
group_c = Sketchup.active_model.entities.add_group
group_a.entities.intersect_with(
false, IDENTITY, group_c.entities,
IDENTITY, false, group_b.entities.to_a
and puts the intersection lines into group_c
