I’ve recently created a complex lattice structure on a building glass roof. “Lines to Tube” was such a huge help as all lines become tubing, unlike Follow Me which stops at intersecting lines.
However, now I wonder if it’s possible to create square tubing instead of circular tubing. Of course the precision could be lowered to 4 to make it a square. The problem is, the profile will be a 45 degree rotated square, like a rhombus.
Is there such plugin or an idea to make this possible?
It might be possible, if the Ruby code isn’t encrypted, to make a small modification to rotate the profile, and draw a polygon instead of a circle, so you don’t have to unsoften the edges.
PipeAlongPath IS unencrypted, but I don’t think it can handle branching paths.
Could you contact the author of Lines to Tubes, and ask them?
