Lines not hidden when face is hidden
Hexagon A May 12 b.skp (175.7 KB)
Hello,
I am hiding most of the components of the hexagonal tube. When I hide the Hexagon Face, some of the lines of other sub components still remain.
Is that a problem? If so, how do I fix it?
Peter Enns
It looks as though those edges were supposed to be in the Hexagon Face components. You can see that here:
You can cut/delete edges and then open the component (e.g., Trapezoid Face) and use Edit → Paste In Place to put them inside.
Or you could delete them and redraw them inside of your components.
Hello,
Thank you for answering. However, after reading your answer, I still had problems.
The lines in the centre of the hexagon, I found out, are part of A Perimeter Lower. If I hide A Perimeter Lower, those lines disappear. Also, if I try erasing those lines, A Perimeter Lower is erased.
If I erase the lines corresponding to the upper trapezoid, no problems appear to be created. The trapezoid is totally intact. So, I am assuming that I may as well erase them. What do you think?
If I just ignore the lines attached to A Perimeter Lower, will there be a problem?
Peter Enns
Oops! Attached the wrong one.
Peter Enns
Erase them.
Then inspect your components for missing faces. If any faces are missing, simply draw them back in.
