LibFredo6 causing startup crash
Hey all, using SketchUp 2026. Libfredo6 seems to be causing SketchUp to crash upon startup every time. Once removed, all is good; I reinstalled, and the same issue… which I have repeated a few times. Anyone having similar issues?
Have you updated it and the Sketchucation plugin?
What version of 26?
hey bmike! update to date with everything. honestly killing me lol
One wouldn’t know from your profile.
Maybe there is a conflict with another extension. You could disable half, see what happens and repeat until you find the culprit. Or disable everything but the Fredo extensions and see.
My apologies for not having the correct info in the profile. (have fixed this), have deleted, and the only everything stays working is with it gone.
Did you contact @Fredo6 ?
any chance you have 1001bit tools installed ?
if you do, can you remove it from the plugin folder and try again ?
