Leader text jumping
Hi All,
Having massive issues with my leader text jumping around. this is happening on multiple projects now. nothing has changed on these drawings or models since i closed them and the text was in the right position.
I first thought it was the leader lines moving causing the problem but now realize its the text itself moving.
In the first image you can see all the text with the leader encroaching the end of the text is no longer aligned with the Tescon note (thats the only one that didn’t jump)
on the second image you can see all the door numbers are out of position by the same amount the leader line overlaps them. D11 for example should not be over the basin and the distance it needs to move is the same as the pink scribble I made.
Does anyone have a way to stop this happening, I have it occurring on almost every project and I cant keep fixing them.
please note these are not leader copies, each one is a new leader as it auto texts what its clicked on and copying them is slower. (Just ruling out it being a copy problem)
