Hi
I’ve been using layout for a long time. I love it
But…
The text editor is pretty lame.
I like to write specifications in layout but have always been frustrated by the fact that you can only make one level of list in the text editor.
I tried importing rtf text and the list numbering still doesn’t work.
I’d like to make a list like this
Hi @thobson … the text editor could use some improvements (columns please!) but I’ve found it does most of what we need it to do, including spec writing.
These were copy and pasted from AutoCAD. We had to reformat the entire sheet though. I suggest doing one paragraph to get started and using COPY STYLE/ PASTE STYLE to format the rest.
If I remember correctly, in order to achieve alternating between text and number prefixes …
At the bottom of the Text menu, select Show Ruler.
Cursor at the start of the line to be indented. Hit TAB.
In the List drop down at the top, select the list style you’d like.
LayOut will continue to number with the indented level style you selected until you outdent.
I hope I understood your question correctly and hopefully this helps. Good luck!
