مرحبا .. عندي ملف LAYOUT SketchUp تلف عندي اريد احد يساعدني او يصلحة الي كيف استرجع الملف رجاءا
Trnslated by Google
Share the file so we can see if it can be recovered. Without that there’s no way for us to tell you. Did you try opening the backup copy?
How can I share the file with you? The file size is 135 KB.
That’s well below the 16 Mb upload limit. Maybe you mean 135 Mb?
Upload it to DropBox and share the link.
Please look at the file as soon as possible, I’m waiting for you.
Chill out! I’m going as fast as I can.
I’m unable to do anything with the LayOut file. Several of the required files are empty. Did you try opening the backup copy? Where was the file saved while working on it? Is it correct you are using a cr acked version of SketchUp and LayOut 2024?
Where can I find the backup copy? The file was saved while I was working on it to an external hard drive.
The backup copy should be in the same directory as the working file.
That’s most likely why the file has become corrupted.
If possible, could you repair the file for me?
Is there a way to recover the file?
No. There’s no way fix files that are totally empty.
Did you find the backup copy?
Another problem could be related to using cr acked software. This has been a problem for other users, too.
You need to slow down and give me a chance to reply to you. Repeatedly hounding my to fix your file isn’t going to help.
I couldn’t find the backup of the file in the same path where we save it.
That would indicate that there was a problem with saving to the external drive. At this point starting over is the only option. And don’t save the file to an external drive while you are working on it.
