Layout showing page measurements not object dimensions
I am longtime SU user with SU Pro just starting to use Layout on windows machine and finding for some reason my dimensions that I add using the tool show perfectly, but later they switch to the page measurement. Example: a wall with a 10 foot length shows up as 1.75 inches which is the measurement on the page. I have tried to find someway to toggle between the two, but have had no luck. Most recently this came up when I moved the view on the page only to have all of the dimensions turn to measurement. The only way I could figure to fix it was to undo until the view was back in the original location. Is there a trick I am missing.
Share your LO file so we can see exactly what you’ve got. There’s surely a simple explanation for what you are seeing but I can think of a number of different ones.
Please fix your profile. It says you are using SketchUp Make
