Layout Setup Dialog box References Tab column spacing
On my iMac with latest updated OS and SU 2023 Pro, When I need to update file references in the Layout Setup Dialog box — References Tab the beginning of
the file name is not visible on the left edge of its column and no matter how wide I make that column I can see the beginning of it. It’s like it is “right justified” and I can’t make it “left justify.”
Is there a setting I’m missing?
There isn’t a setting in LayOut for that. If you make the Document Setup window wide you should be able to drag that column to make it wide enough to see the entire path unless the path is incredibly long.
FWIW, you can update the reference from the SketchUp Model panel when you have a viewport selected.
Screenshot - 9_17_2023 , 10_09_34 AM
Please complete your forum profile with SketchUp version, OS version, and graphics card model.
Can you share a screenshot?
Is the file on a shared location? (Users/Shared)
If you go to ‘Go to’ in that dialog box, will it direct you to the right location?
