Look in the SketchUp Model panel on the right. Click on the Reset button in the Camera section.
With every viewport in the template having its Camera properties modified it will be a very difficult template to work with since the viewports will not show the scenes as you create them in the model.
Going back to your original question, until such time as the developers sort out the display of section planes, here’s a simple work around.
- In the SketchUp model create a group from slice for each section.
- Give the groups from slice a tag. I called it "Groups from slices.
- In LayOut ensure the Groups from slices tag is displayed for the viewport. Use those groups to align the section indicators. I’ve just done the top and bottom here.
- After your sections are marked, go into the Tags section of the SketchUp model panel and turn off the tag for the Groups from slices.
