Layout not connecting in SketchUp 2023
I recently installed SketchUp 2023 and Layout. Layout does not highlight on either the toolbar or drop down menu. Any clues as to what’s going on? This is the first time I’ve had this problem after years of using SketchUp.
What do you mean?
Hi. I can’t send files to Layout in SketchUp 23. Is it possible that it’s not fully installed?
Are you still using Yosemite as your profile indicates? Please complete and update your forum profile.
Did you actually install SketchUp and LayOut or are you running SketchUp from the .dmg file?
Make sure that you copied the whole SketchUp 2023 folder to Applications. If LayOut is not in the same folder as SketchUp, the menu item and buttons won’t be available.
