Attached SketchUp file consistently crashes in Layout when trying to render scenes as Hybrid. Item 2 seems to be the culprit as scenes “Item 1 - Pict” and “Item 3 - Pict” will render as Hybrid on their own. Tried eliminating components in Item 2 in an attempt to fix but still having problems.
Additionally, trying to export scenes from SketchUp as pdf files also consistently causes crashes.
Could this be a memory issue with Hybrid rendering? When I divide a large scene (that crashes when rendered as Hybrid) into smaller scenes, the smaller scenes render as Hybrid without issue - see attached Layout file - Scenes on Top of Each Other.
I have been having an issue very much like this since transferring to SU/LO 2018. It seemed to be to do with components downloaded from the Warehouse. I never identified which but drawings that only used components I created did not have the same problem.
The techie guys did start looking at the issue but i don’t know if they got anywhere with it. I haven’t looked at your drawing so cannot say if you have suspect components.
