Layout File / Insert command is grayed out. It’s visible under the file selection but is inactive. Help
Your profile says you are using SketchUp 2024. Is that correct? Is it a cr acked version? Did you install it correctly? Have you selected a template to use? You cannot insert anything unless you’ve already selected a template.
