Hey everyone, I need an immediate help tbh. I made a layout file and prepared my entire presentation on it. Now I cannot open the file. I know there we some missing links and I check that missing link is a reason for layout to crash in 2020 version. I have a meeting in the morning and I cannot redo it.
Share the LO file and give us a chance to see if we can get you sorted out. Assuming it’s larger than 16 Mb, uplooad it to DropBox or WeTransfer and share the linlk.
that is the problem I am having as well. But the file has no reason to be corrupted. I saved it an hour ago. I wasn’t working on it on cloud as well. Only explanation I found was that It used to happen in 2020 when there is a missing file inside the Layout references.
I really don’t know what to do. And frankly, I hated Layout for this
I haven’t ever had this problem with my own LO files. Hopefully Colin will have some success.
FWIW, I looked at the .skp files in the LayOut file. There’s a fair amount of incorrect tag usage and some unused content.
The error stems from invalid label entities that we attempt to discard at load time. It is possible to recover nearly all of this file, and I have already sent @burakcankaya a fixed version of the file via PM. We will work to fix this issue with file loading such that removal of these invalid entities does not cause a crash on file load.
