CPUs with higher clock speeds and a larger cache will obviously be better. Keeping files saved locally so you don’t have to wait for file access like you do with network or cloud storage will help.
There’s a limit to how fast the user can actually think and move. For my commercial work with SketchUp and LayOut, my computer isn’t the bottleneck. The slow downs come from me trying to decipher the information I’ve been given or waiting for the right information so I can proceed.
That’s a good way to put it. I can think of a bunch of analogies in other disciplines where this is also true.
When I was at the 3D Summit this past summer I showed this problem to one of the Layout developers. Not only would the scale of the viewport change when I resized it, the dimensions would not follow. The dimensions would not even turn red to indicate they were no longer connected to the model. So very weird. He took a copy of my files and presented the issues to the team. I don’t expect to hear back from him, but I hope this is fixed in the 2027 release.
Anyway, yes, I also experience these issues as well. Pain in the butt!
I’ve had the same issues, despite real efforts at good hygiene, and have been seeing this complaint from others. I think it’s clear enough something got broken with the latest release. It’s a shame. My workaround has been to be very very careful with order of operations when changing viewports, frequent viewport regens, frequent saves. It’s a bummer, really slows me down.
Yeah, I discovered this about a month ago or so and complained about it in the forms and I think Colin or someone said they had an update to fix this, but it hadn’t been issued yet. I was like dude just issue the dang update because it’s frustrating. And it’s one drawing I had to put the dimensions in a group to keep them from stretching when I change the size of the view port. Let’s SketchUp doesn’t realize is that with AI coming out there’s gonna be a lot more competition so they need to get on the stick.
I have exactly the same problem: About the distortion, it is partly temporary, meaning it takes a loooong time to bring any changes, even the simpler ones, like resizing the window having to preserve scale. It also loses the determined scale; i.e., let’s say I have a viewport with the scale at 1:50, and I move the edge to center it on the model, having ticked the preserve scale option. It will temporarily distort the image and adjust the scale to a random number.
Just having to select the scale over and over..
I work with clean files, scenes, no ambient and still happens the distortion to the point I need to constantly “reset” button view, select scene again, select scale and adjust viewport. Over and over. Next time this happens will share a video. Never happened with 2024 version only came with 2025/2026!
I haven’t looked at this specific project, but in general, I run into a lot of problems when I work in LO 2026.
Last week, I had a model that was extremely slow; refreshing took forever, clipping masks were impossible to use, and links to external documents like Excel sheets stopped working.
I opened that document in LO 2025 and was able to continue working smoothly and without any lag.
So since then, I’ve been using “Send to Layout” exclusively to import the model into LO, which automatically opens in the 2026 version. I then close it immediately and continue working in LO 2025.
That sounds really frustrating, especially after years of using LayOut without these issues. Hopefully sharing the file and exact SketchUp/LayOut version will help identify what’s causing the viewport distortion.
@remakeinterior I’d turn off auto rendering in LayOut preferences while you set scales and line things up, then hit Render once. not sure it fixes the 1:116 jump but at least it stops the lag on every drag
@balikahomes if it started with 2025, 2024 might be the safer bet on an Intel Mac. it’s still on the all versions page if you’re on Pro. try it on a copy first
