Yesterday I’ve updated SU 2021 to SU 2021.0.1.
Sketchup seеms to work fine, but today I put my models to Layout and figure out that
model camera setting doesn’t work at all (Standart View, Orto and Scale).
So LayOut is useless.
Already tried:
Manually render Model in LO
Restart Mac
Reinstall SU and LO
Create new clean model and LO file
Nothing helps.
Where can I download previous version of LO 2021 and SU 2021 before latest update?
Or someone know how to workaround this bug?
System Info:
– MacBook Pro 15 2017
– macOS Big Sur 11.1
– External Display LG Ultrafine 5K
If you want the camera view in your SketchUp scene to show up in LayOut, click the Reset All button, then choose the scene you want.
If you want LayOut to control the camera position, still Reset All, choose the scene you want, then change the camera settings.
Whenever the Reset All button is showing, it means that you have set LayOut to take control of the view, and any camera changes you do in the model won’t make it look any different.
For most of the issues, relinking the right viewport to the other file, and then back to its intended file, fixes things. For some reason it current sees itself as a model, but isn’t selectable with a click. You can select it with a right to left drag, but even then a right-click on the viewport doesn’t give the usual model options.
It is curious that while the link is broken that going to vector or hybrid shows the rectangle in the upper right, but fixing the linkage solves that too.
@trent can you see if this example file relates to a known linkage issue?
In a nice coincidence, I was checking on something unrelated, and noticed that one issue being looked into yesterday is a variation of what you saw. So, there is good reason to hope that the problem will be fixed.
The cause of the issue is that the camera was disabled in the scene in SketchUp. The work arounds are either do do the relink trick I mentioned, or make sure the camera is enabled in the scene. You are going to take over the camera in LayOut anyway, so whether it’s updated in the scene or not, you can still do what it is that you want to do.
Whenever the problem gets fixed, you will then get away with having the camera not be updated in the scene.
After more than a month with this issue, still no solution ? @dan.sheb where did you find the old version of SU, 21.0.338, preferably in French.
As far as I can see, we are not able to change any camera setting, tags, style etc. while any scene (but Last Saved) is active, the viewport won’t update. It makes it impossible to work simply with section plans or style, while you need a scene for each view and each parameter…
