LayOut 2026 – SketchUp Model Shifting and Disappearing When Resizing Viewports
Hello everyone,
I’m currently using LayOut 2026 and experiencing a major issue with SketchUp viewports that I haven’t been able to resolve.
Even though Ortho and Preserve Scale on Resize are enabled, every time I try to resize or crop a viewport, the SketchUp model shifts unexpectedly within the viewport boundary. Sometimes it also appears to change scale, despite the scale being set and preserved.
For example, I might have an elevation correctly displayed at 1:25 and simply want to reduce the viewport margins to show a specific area. Instead of just cropping the visible area, LayOut shifts the entire model to a different position. Even the viewport boundary itself does not stay in place, the drawing moves, sometimes completely outside the visible area. I then have to enlarge the viewport just to locate the model again.
I’ve also noticed the following issues:
  • Changing SketchUp tag visibility through LayOut’s SketchUp model panel triggers regeneration, which can also shift the model unexpectedly.
  • The same problem occurs when using clipping masks.
  • The issue occurs with newly inserted SketchUp viewports, not just duplicated ones.
  • I’ve even reproduced similar behaviour using a different SketchUp model in a completely new LayOut document.
All my SketchUp scenes are correctly configured, using Parallel Projection, standard elevation views and section planes. They display perfectly in SketchUp. The problem only occurs when working with them in LayOut.
I’ve followed several tutorials and tried different settings, but I cannot reproduce the normal viewport behaviour shown in those tutorials. LayOut has also crashed during my attempts to resolve the issue.
I’m using LayOut 2026 (26.2.243) on Windows 11 with an NVIDIA GeForce RTX 4070 Ti.
Has anyone experienced something similar, or does anyone know what might be causing this? Could it be related to viewport regeneration, camera positioning or a bug in LayOut 2026?
Any suggestions would be greatly appreciated, as this is making it extremely difficult to prepare accurate technical drawings.
Thank you!
This is a known issue, it should be fixed in the next release of Sketchup. The date when this will happen is/has not been given.
