I’m using ConDoc Tools for my drawings. When I insert the drawing to a page and it appears with the yellow “!”. When I try to resize it before rendering it, the Layout Bugsplat occurs. However, if I render before resizing, everything is fine. I just switched from 2019 to 2021 - that never happened before.
EDIT: I sent some Error Reports. Could anyone take a look at them to try to figure out what’s causing the issue?
Not sure if that truly matters. But no, it doesn’t happen if I make any changes in the viewports, including changing to Raster mode. Simple re-rendering seems like a workaround. I am accustomed to some workflow though. I insert the drawing onto page, resize, rerender.
The most interesting thing is that I tried recreating this issue on my laptop. And there are no problems, the inserted drawing is already rendered properly just after inserting and resizing it doesn’t create a bugsplat.
