成组后的图层移动问题 Layer movement after grouping
我在图层1做两个box后各自成组,然后把1个box移动到图层2,隐藏图层1的时候两个box都隐藏 了,请问这是处于什么考虑做这样?
After I make two boxes on layer 1, I group them respectively, and then move one box to layer 2. When hiding layer 1, both boxes are hidden. What is the consideration?
Layers are now called Tags and behave the same way.
Do not make the boxes ‘on layer 1’ always keep layer 0 or untagged as the active layer/tag.
The reason your second box disappears is the Geometry within the Box has layer 1 assigned to it.
Only assign a layer/tag to groups/components etc never to raw geometry.
So make two boxes with layer 0 or untagged active, then assign one to 1 and the other to 2.
It is difficult to write clearly so the translation works properly with the layers name change, if you are using 2021 you should only be seeing tags, but how that translates…
Here is a gif that may help to understand.
Tags
i understand. thanks
