Dan,
This applies only to loading “net/http” within SketchUp’s Ruby process.
A discussion of processes is probably outside of the scope of this forum. What is important is the environment in place when an external command is executed in SU. I am speaking only about Windows, if anyone (Dan?) can test these issues with OSX, it would be appreciated.
I’ve attached three files:
info_dump.rb
generates output for two below files.
info_dump_ruby_from_su.txt
- generated by stand-alone ruby install run from the SU Ruby Console.
info_dump_ruby.txt
- generated by stand-alone ruby.
So, regarding your phrase ‘This applies only to’, you’ll notice that the environment that is passed to stand-alone ruby run from SU is not the same as the environment when run outside of SU. In particular, ENV[‘SSL_CERT_FILE’] is set to the SU location.
Hence, any apps shelled out to from ruby in SU do not receive an environment that is the same as if they were run stand-alone.
BTW, if you’re aware of the cert file, why was SU2017 released with one dated 2014-09-03? Of course, we won’t even talk about the version of OpenSSL, etc.
info_dump_ruby_from_su.txt (3.5 KB)
info_dump_ruby.txt (3.3 KB)
info_dump.rb (2.4 KB)
Below is the ‘Native Ruby’ section of what I’m currently using in SU2017:
-------------------------------------------------------------------- Native Ruby
ruby 2.3.5p310 (2017-05-01) [x64-mingw32]
Gem::VERSION 2.5.2
DBM::VERSION GDBM version 1.10. 13/11/2011 (built Apr 3 2017 16:32:08)
GDBM::VERSION GDBM version 1.10. 13/11/2011 (built Apr 3 2017 16:32:08)
OpenSSL::VERSION 1.1.0
OPENSSL_VERSION OpenSSL 1.0.2k 26 Jan 2017
OPENSSL_LIBRARY_VERSION OpenSSL 1.0.2k 26 Jan 2017
Psych::VERSION 2.1.0 LIBYAML_VERSION 0.1.7
Readline::VERSION (ext) 7.0
Zlib::ZLIB_VERSION 1.2.11
Socket Ok
Win32::Registry Ok
WIN32OLE Ok
From initial testing (more to come) everything works fine. In case you’re wondering, OpenSSL 1.1.0 will only work with Ruby 2.4+. And, 2.4+ will not work with SU due the Integer issue.
But, since 2.3 works with SU, it would allow plug-in devs to start testing with # frozen_string_literal: true
. There’s also 147 warnings generated by code included with SU…
Ruby v2.2 - trunk docs
