Hi i Have made a “L“ groove on a side panel of a cabinet box and i want -after a hidden execute- to hide the L groove and to show the side panel normally Look the img
How can i do it?
How can i do it?
I don’t have the full context on what you are doing, but you could have two panels, one with the L groove and the normal one. Have a “visibility” parameter that toggles the visibility between them. You’ll need to apply the same parameters to both panels, so they behave the same for everything else.
I hope it makes sense.
if you want to be able to scale the panel and/or adj the depth and length of the L, then you probably will want to make the component with several parts to enable you to select those options. a fixed “cut” will change size if you scale the panel (or not change if you can use the pull-push tool- which sort of makes altering the cabinet sizes a bit more manual work).
example:
example panel w L.skp (301.4 KB)
OK Thank you
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
