Jpeg import and scale problem
In the past, I could import a JPEG as a texture, scale the object, and then cut into and extrude, etc, but now with 2025 I am having issues when scaling the object and then making a copy of a part of the “Block”! The block does not keep the position and scale of the texture if I copy and paste sections out of the original scaled block the texture jumps to a different scale and position!!
!What can I do? Say I create a block - add a texture with the image of facade over the block - scale the block to a known element size and then start extruding and cutting into the original block to create the item that was on the jpeg texture! (building or element / plan or sections)
Its just not working anymore!
FYI: AutoCAD has blocks. SketchUp has Groups and Components. It may make a difference as to which type you are using.
When you apply the texture, are you applying it to the outside instance, or directly to the inner faces of the definition ?
