Joining 2 roof tiles together help
So I have these tiles, on the left side of the roof and right side, inbetween (the corners) is the empty gap that I want to join the tiles together to make a triangular tile to fill that gap, these tiles i got from the warehouse, and just copy pasted against the roof, but these corners I have no idea, please help!
Temple-C1.skp (281.3 KB)
Before you connect the corners, do you intend for the tiles on the left to be upside down?
Are the eaves on the right supposed to be lower than the one on the left?
Your roof would be easier to work with if you use a tile roof texture instead of adding the file bloat with these groups. If you must use the 3D objects it would be better if they were instances of the same component instead of groups.
Look at real tile roofs to see how the corners are done. The tiles at the corner need to be cut and there would be a series of ridge tiles down the corner.
Yeah I was gonna change the left ones to be upsidedown, the eaves are supposed to be equal and I was gonna fix those but I wanted to fix this issue first.. since I also need to repeat this to all 4 sides.
You need to fix those issues before you try to connect the corners. Otherwise you are wasting your time.
If you’re going to use the objects that you have, make copies that extend out past each other at the corner and then trim the ones where they meet.
Alright.. thank you!
As an idea, if you want to create 3D geometry with a good arrangement of the tiles.
Using geometry nodes then import it in SketchUp
