L’une est plus haute que l’autre, ma pièce n’est donc pas parallèle (A !// B) et je pars d’un quart de rond vers un chanfrein. J’ai essayé sauvagement mais sketchup fait un gros trou.
Comment procéder svp?
Does the face appear when you draw a line on one end of the hole? It should. If not attach a copy of the file and one of the experts will show you how to make the face.
Stitch in between the arc and the edge for the chamfer. If you divide the edge for the chamfer into the same number of segments as in the arc you’ll get a nicer surface. Here Endpoints are turned on in the Edge settings for the style.
