@john_drivenupthewall massmaterialimporter
Hello John -
I was perusing another thread (since closed) in which you said you were working on a MassMaterialImporter for v2018.? Any chance I could try your solution? (Installed the massmaterialimporter.rb (zipped to rbz, installed successfully - but “running the extension” does nothing.
Run, select 1 file (rather than a directory.?), then… nothing. Rather than troubleshooting this old version I thought I’d try your solution instead. (Forgive me but I have no experience w/ ruby outside of installing extensions so your instructions will have to be specific / detailed if copy/paste/edit in a Terminal window is required.) Thank you!!!
Better ping @john_drivenupthewall inside the message instead of in the title.
If you want to contact anyone on the forum directly, you can click on his/her avatar and send a Private Message to him/her.
I also changed the category.
