JHS Powerbar
Hiya All,
Upgraded to Sketchup 2026 & am trying to get JHS Powerbar to lay bricks along an arc, i.e. selected path, however the brick components do not follow the path.
I can’t understand what’s wrong. Any pointers anyone?
SU 2026 + JHS Powerbar 2020
And what do they do instead? Are the component axes correctly positioned?
The axis should be correct .. but shouldnt the copy along path follow the path selected?
Once again… what do they do instead? Do they not appear? Do they multiply in a straight line?
You are the only one who sees what it does and what happens, so it is necessary to provide this data when asking for help.
What does ‘should’ mean? Are they correctly positioned or not?
‘Copy along path’ also working
What is the set distance between elements?
Thanks you .. finally managed .. it was the axis
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
