Issues with Creating Finite Guidelines Between Two Endpoints
Hello All,
I am trying to create vertical guidelines between building floors on my isometric diagram. I want to create one guideline between the lower-left corners for the 1st and 2nd floor and another guideline between the upper-right corners for the 1st and 3rd floor.
For some reason when using the tape measure tool and selecting the endpoints, an infinite guideline is created instead of a finite one between the points. As a workaround, I have temporarily drawn two lines in place of the guidelines under the tag “Vertical Reference Lines”. However, I still would like to use guidelines rather than drawn lines.
Would anyone know what the issue may be? Below is the attached file for reference.
22 - Isometric Diagram.skp (1.6 MB)
To get a guidepoint with a tail you need to start from an endpoint/corner or from another guidepoint.
Why do you want to use guides for this? What you’ve done would normally be the preferred method (although you should group those edges and give the tag to the group rather than to the edges themselves). Using a dash style with the tag gives you a lot more control over their appearance in LayOut and you can have vector dashed lines which you can’t get with guides. Guides are also much more volatile than actual edges.
Here’s an example in LO. The viewport is rendered as Hybrid which yields Vector linework. I changed the dash style line scale to make it lighter than the rest of the linework and also made the dashed lines blue.
Isometric Diagram.1.skp (1.5 MB)
It worked for me doing what @DaveR said.
