The following code allows you to create an ‘animal’, a line for a ‘simple animal’ and a line with some lines angled off it (legs) for an ‘animal’.
Run Animal.make_animal in the Ruby console and it makes an animal with legs. The user can select the thorax length and number of legs.
The user can select the resultant animal in the model (it goes blue as selected) and run Animal.edit_animal and this lets him/her edit the thorax length and number of legs.
So far so OK.
The issue is, if I do an undo it undoes everything all the way back to before I made the animal. The animal disappears, not just the edit.
Is there something wrong with the way I implemented start_operation, commit_operation in the Animal.edit_animal method code?
Thank you for any help you can give me.
class Simple_animal
def initialize(animal = "worm", thorax_length = 1, *arg)
puts "In initialize in Simple_animal class and @animal_group is #{@animal_group}"
model = Sketchup.active_model
entities = model.entities
if arg[0].is_a? Sketchup::Group
then
@animal = arg[0].definition.get_attribute("Animal", "animal")
@thorax_length = arg[0].definition.get_attribute("Animal", "thorax_length")
@animal_group = arg[0]
else
@animal = animal
@thorax_length = thorax_length.to_f
@animal_group = entities.add_group
end
end
def show_animal
@animal_group.entities.clear!
puts "In show_animal method in Simple_animal and @animal_group is #{@animal_group}"
@animal_group.entities.add_line [0, 0, 0], [@thorax_length, 0, 0]
@animal_group.definition.set_attribute("Animal", "animal", @animal)
@animal_group.definition.set_attribute("Animal", "thorax_length", @thorax_length)
end
def get_thorax
old_tl = @thorax_length
data=inputbox(["Enter new thorax length"],[old_tl],"Edit length of thorax")
if data
then
@thorax_length = data.first
else
get_thorax
end
end
def Simple_animal.make_animal
model.start_operation("Make simple animal", true, false, false)
data=inputbox(["Animal name", "Body length"],["Worm", "4"],["", ""], "Simple Animal Data")
name = data[0]
thorax = data[1]
simple_animal = Simple_animal.new name, thorax#String, Numeric
simple_animal.show_animal
model.commit_operation
end
def Simple_animal.edit_animal
selection = model.selection
animal_as_SU_Group = selection.first
puts"animal_as_SU_Group is #{animal_as_SU_Group}"
animal = Simple_animal.new(nil, nil, animal_as_SU_Group)
animal.get_thorax
model.start_operation("Edit simple animal", true, false, false)
animal.show_animal
end
end
# class Animal sub-class of Simple_animal
class Animal < Simple_animal
def initialize(animal = "Insect", thorax_length = 1.0, legs = 0, *arg)
puts "In initialize in Animal class and @animal_group is #{@animal_group}"
then
@legs = arg[0].definition.get_attribute("Animal", "legs")
else
super(animal, thorax_length, *arg)
@animal = animal
@animal_group = Sketchup.active_model.entities.add_group
@legs = legs
end
end
def show_animal
puts "In show_animal method in Animal and animal is a #{@animal} and @animal_group is #{@animal_group}"
posneg=1
@legs.times do |i|
posneg=-1*posneg
x = @thorax_length / @legs * i
y = posneg * @thorax_length/2.0
z = -@thorax_length/2.0
@animal_group.entities.add_line [x, 0, 0], [x, y, z]
end
@animal_group.definition.set_attribute("Animal", "legs", @legs)
end
def get_legs
old_legs = @legs
data=inputbox(["Enter number of legs"],[old_legs],[""],"Edit number of legs")
if data
then
@legs = data[0].to_i
else
get_legs
end
end
def Animal.make_animal
model.start_operation("make animal", true, false, false)
data=inputbox(["Animal name", "Body length", "Number of legs"],["Insect", 4, 6],["", "", ""], "Animal Data")
name = data[0]
thorax = data[1].to_f
legs = data[2].to_i
animal = Animal.new(name, thorax, legs)
animal.show_animal
end
def Animal.edit_animal
animal = Animal.new(nil, nil, nil, animal_as_SU_Group)
animal.get_thorax
animal.get_legs
model.start_operation("animal_edit", true, false, true)
animal.show_animal
end
end
