Are there no longer layers within layout? If not, how did they preserve that functionality?
There are layers in LayOut. What makes you think they were removed?
Maybe you clicked the X in the right corner of the Layers panel to remove it from the tray? If so, you can add it back under the Window menu.
Are you still using SketchUp/LayOut 2022? In any case it’s the same in all versions since LayOut was released.
Dave, I didn’t have that option appearing. I restarted and now it’s fine, I was following along with a tutorial and just didn’t see the option. Thank you much
What about tags? In some tutorials I am seeing the users turning off objects by tag in layout.
Yes. That’s in the SketchUp Model panel in the tray.
Tag visibility is a per-viewport thing in LayOut.
Thank you very much
