I used this method:
model = Sketchup.active_model
selection = model.selection()
model.active_entities.add_group(selection).definition.save_thumbnail(filename)
This method is too slow,I want a faster way
I used this method:
I don’t think, if there is other method at all.
However you may try to check the different supported file formats (bmp, jpg, png, tif, pct, and gif) if one of it is faster or not…
What are these thumbnails being used for?
These thumbnails are for display,the waiting time is a little long
Thank you for your attention. I’ll try it
Don’t do that rigmarole. To save out a thumbnail of the model try …
filepath = File.join(ENV['HOME'],'testthumbnail1.jpg')
status = model.save_thumbnail(filepath)
See:
Sketchup::Model#save_thumbnail
If the model is already saved to storage, then you might also use the Sketchup::save_thumbnail
module function.
However both methods just reads the internal thumbnail image as it was last saved.
If you want to save a thumbnail of the current active view, irrespective of what was last saved, then use Sketchup::View#write_image
with 256 pixel arguments for the width and height.
filepath = File.join(ENV['HOME'],'testthumbnail2.jpg')
model.active_view.write_image(filepath, 256, 256)
I’m sorry, I didn’t make this clear.I want to get thumbnails of the selected model in the Su viewport.
Thank you for your answer. I tried your method, but it was not what I wanted.
SketchUp doesn’t have a concept of thumbnails for a selection. Only models and components.
What you are doing, or what Dan suggests with writing out an image of the whole view is the closest you get.
I want to get the thumbnail of the selected component in the Su viewport (preferably changing with the viewing angle).
I used this
model.definitions[0].save_thumbnail(filePath)
and it’s getting faster.But thumbnails don’t change with the angle of view.The original method is OK.
That sounds like this issue: ComponentDefinition#save_as and #save_copy always generate thumbnail from same angle · Issue #765 · SketchUp/api-issue-tracker · GitHub
Thank you for your answer. I’ll go and have a look
