Oh okay! If it was a specific angle that would have made my work easier!
It is a specific angle. Just not 30Ā°.
I am exporting the current view from my SketchUp model (File> Export> 2D graphic) and importing to Photoshop. I have been exporting in JPG format. Thereās not PNG option though.
Yeah, I understand.
Yes there is. You need to select it in the export options.
I canāt seem to find it.
Thanks for sending this in!
Aah! It was right there and I couldnāt see it. I have been spending too much time on this and is completely zoned out!
I canāt see any significant difference in quality between JPG & PNG.
This is a snapshot of the image saved in PNG. Still not the best quality and lines are broken. Is there a way to improve the quality?
You could send the file to LayOut, render the viewport as Hybrid and export thePNG from there.
The quality is much better that way. thanks!
Also, all this discussion assumes you are using parallel projection, which ISO would be, however your sample Image in the first post appears to be in perspective. If you are wanting to create visual document consistency using a perspective camera you will need to understand the Field of View settings as well.
