I have been noticing recently that it has been easily possible to set the dimensions of dynamic objects to totally arbitrary decimal values that are not on my desired minimum drawing grid of 1/16 of an inch. This is especially true if I use the scaling command to stretch some object. Is there some way in SketchUp to set a minimum dimension snapping unit so that no dimensions are not on the nearest 1/16th of an inch?
Yep!
Model info/Units will allow you to set your units, minimum and snapping!
