I have created some mostly part-elliptical-shaped faces from a custom Ruby script I wrote, using add_faces_to_mesh
. I can use Joint PushPull to make them into 3d solids.
But I’d like to delete the softened edges to make a single face on the side of the solid, either before or after PushPulling it.
How might I do that (in principle) if there isn’t such a plugin.
I could do it manually, but there are around a hundred edges in each face, and about a dozen different objects to do it to, so it would be tedious and error prone.
Any suggestions?
PS. Google may have the answer here:
Just found that after writing above post.
Will see if it still works in SU 2017.
