I just want to ask if SubD is good for wood carving because AI says, it’s not good for wood carving. I don’t if it’s true…
Your question is not clear or specific enough to answer. SubD clearly cannot carve a piece of wood as it is software and not a knife. Do you mean is it useful for modeling in SketchUP shapes that one might typically carve in wood? Maybe. It’s one of several extensions that present a method of working with organic shapes in SketchUp. It really depends on what you want to model, what is “wood carving” in this case?
An easier question to answer clearly would include a photo and say, “will SubD help me model this shape in SketchUp?”
Ive been trying to get AI to do anything other than create crappy google slide docs and kiss my ass and yet, no luck.
I want to sculp this in sketchup. So i have to use artisan 2
But i don’t find free lifetime so artisan 2 plugin so i tried to use SubD instead
Is there a tutorial how to make this? and is there any free alternatives for artisan. And i don’t want to use AI
Why would you expect a free lifetime to Artisan 2?
By the way this is an Ah-tay bed’s Column which is filipino bed, Is there a tutorial how to make this? Ive tried making this but flop…
i’d start with the built-in tools for the main shapes. for the turned base and finial, draw a closed half-profile and use Follow Me around a circular path. if the pierced middle is flat, trace its outline and openings as closed shapes, then Push/Pull it to thickness. the carved details would need separate modelling.
