So here is what my model looks like in sketch up
and heres what it looks like in illustrator as a dwg/dxf
Somehow yesterday I was able to create layers in sketchup, like so, and they exported as consolidated shapes. I can’t remember what I did, but I tried making groups and components to no avail.
We need to understand your terminology first.
You talk about creating layers in Sketchup. I expect you mean tags. Sketchup doesn’t have traditional layering, although Layout does.
When you say “they exported as consolidated shapes”, what do you mean by “they”? Do you mean the geometry you created?
You say you tried making groups and components but failed. Making selected geometry into a group or component is extremely easy and should be something you do all the time to ensure elements stay discrete and don’t interact with things you don’t want them to.
As usual, it would be easier to work out what your problems are if we had the actual SU file you refer to.
Yes tag, I meant.
They lines (which should up as paths on SU/LINE on Illustrator)
By they I meant all the lines/shapes/paths in the SU model
Well I think I made the groups/components I just don’t know where they show up, but my point was that exporting the file with groups/components didn’t consolidate the lines (as shown in illustrator)
I’ll attach the file later I have to fix something first
I think there may be a language issue here.
If you make groups or components, they show up in two ways. Firstly, when you select something that is part of a group, you will see its bounding box appear. Secondly, there is Outliner which lists all the groups and components.
I can’t help with Illustrator as I don’t use it.
