I would like some advice on how to make my work more easier. What I wanted to know are there any plugins that can allow me to create an interior wall inside of any vehicle such as a truck or a car without making a huge messy work. Or are there methods that could help me with creating an interior wall. I would appreciate your helping with this.
If you have any questions, then do not hesitate to ask.
The quick method: Make a copy of the shell, paste it in place, then scale the copy around center (hold down option on Mac, I think Ctrl key on Windows).
easy way also, since your faces are correctly orientated, select all and use the plugin “joint push pull” by fredo6. Just two clicks ! Make sure the finishing option “thicken” (keep original faces) is ticked before validation
Alright. I have tried Joint Push Pull but for some reason, it shows me an error message. No matter how I do it, I still get the same error message. It must be the model that is not allowing it for some reason
Hey @Sparda , Sorry I got stuck in Detroit for a bit without my computer. Here is a quick example of scaling a version of the shell to create an inner skin. This is a quick but not necessarily pretty way to get an internal surface and might work depending on what you need the model for. You can stitch the two skins together but it can be tedious and there are other methods including plugins that are viable.
If you do attempt this route, make the outer skin component unique so you can work on either one while hiding the other and make separate changes to each shell.
