# Instance not showing
**URL:** <https://forums.sketchup.com/t/instance-not-showing/349369>\
**Category:** Trimble Connect\
**Tags:** entity-info, instances\
**Created:** [August 24, 2026, 1:34pm UTC](https://forums.sketchup.com/t/instance-not-showing/349369 "2026-08-24T13:34:27Z")\
**Showing post:** 2
**Author:** ![MikeWayzovski](https://sea2.discourse-cdn.com/sketchup/user_avatar/forums.sketchup.com/mikewayzovski/32/98346_2.png) [@MikeWayzovski](https://forums.sketchup.com/u/MikeWayzovski)\
**Post date:** [August 25, 2026, 8:05pm UTC](https://forums.sketchup.com/t/instance-not-showing/349369/2 "2026-08-25T20:05:44Z")
DC 's are having issues with instances. While they can be used internally (outliner/Layout/Generate report), they are not handled well in export. Check this thread:
> [@Dynamic component instance name](https://forums.sketchup.com/t/dynamic-component-instance-name/130489/9):
> Unfortunately redraw doesn’t appear to fix it. It might be a bug. @MikeWayzovski @eneroth3 Thank you both for the suggestions slight_smile
Your best shot is to add the instancename to the DC:
 ![image](https://global.discourse-cdn.com/sketchup/original/4X/6/6/2/6622b8aea3d3c5fe19e1779b1072415e6b0e582a.jpeg)
Here’s a little aixtension:
[instance\_name\_to\_dc\_20260825.rbz](https://forums.sketchup.com/uploads/short-url/mSa53tHEKkLBq7wEZrIbVWHN94Q.rbz) (3,8 KB)
_[View the full topic](https://forums.sketchup.com/t/instance-not-showing/349369)._
