I put all of the necessary files from sdk_tools/plugins/sketchup in sketchup tools folder. Plugins folder doesn’t exist and I can find SketchUp only in programs files… there are no new toolbars or export as .VMF in the menu.
Please help me!
Do not ever put anything in the “Tools” folder. This is for SketchUp internal use, and only internal OEM files will be loaded from “Tools” in SketchUp versions 16.0 and higher.
The “Plugins” folder has been moved to the User’s %AppData% folders path since SketchUp v2014.
%APPDATA% is:
“%SYSTEMDRIVE%/Users/%USERNAME%/AppData/Roaming/”
Extensions and plugins should be installed from RBZ (zip) archives. Window > Preferences > Extensions
Click “Install Extension…” button.
Browse to where the RBZ archive is, and select it.
Click OK button, answer Yes the popup security message.
Check the “Extensions” menu for any new items or submenus.
Toolbars need to be switched on manually. ViewToolbars…
