# Inserting a group or component with Ruby API
**URL:** <https://forums.sketchup.com/t/inserting-a-group-or-component-with-ruby-api/114936>\
**Category:** Ruby API\
**Created:** [January 30, 2020, 11:07pm UTC](https://forums.sketchup.com/t/inserting-a-group-or-component-with-ruby-api/114936 "2020-01-30T23:07:47Z")\
**Showing post:** 2
**Post date:** [January 31, 2020, 12:15am UTC](https://forums.sketchup.com/t/inserting-a-group-or-component-with-ruby-api/114936/2 "2020-01-31T00:15:35Z")
**(1)** A short piece of code (_snippet_) can be posted [correctly](https://forums.sketchup.com/t/how-to-colourize-code-on-the-forum-wiki/46189) in the forum.
(I’m not going to download such a small file and open it in my code editor.)
**(2)** A group of **_what_**? All the entities you’ve created in the method ?
If so, then do not add them to the **model’s** entities collection. Instead create a group or a component definition, and then add the geometry to their entities collection.
_from an example in the [`Sketchup::Group`](http://ruby.sketchup.com/Sketchup/Group.html) class documentation_ …
```ruby
# Add a group to the model.
group = Sketchup.active_model.entities.add_group
group.entities.add_line([0,0,0],[100,100,100])
You can also make a reference to the group’s entities collection object …
```ruby
# Add a group to the model:
# Reference it's entities collection:
ents1 = group.entities
enst1.add_line([0,0,0],[100,100,100])
Be sure to quickly add drawingelements or objects to the group’s entities or the SketchUp engine will delete the groups “out from under you”.
Many coders immediately put a cpoint at the group’s origin to prevent SketchUp from deleting the group. …
```ruby
# Add a guide point at the group's origin:
cpt = enst1.add_cpoint([0,0,0])
… then later after adding things to the group, they delete the guide point …
```ruby
cpt.erase!
_[View the full topic](https://forums.sketchup.com/t/inserting-a-group-or-component-with-ruby-api/114936)._
