Insert guide inside cilinder
Hi,
I drawed a cilinder with 10mm radius and 100mm length. It will be used as a shaft in my model so I would like to put a guide right inside this cilinder in a way that this guide will go throw to the infinite passing right in the midde of the 2 circle faces. How do I do that?
I discovered! How do I delete this qustion?
Describe your solution instead so that others get a solution if they find your question…
I clicked in both circles and clicked in FIND CENTER. After that I used the RULE to make a straight line from both centers and the infinite guide appeared perfectly :slight_smile:
