Inputting exact dimensions to draw a cube
Hello all,
It has been sometime since I drew in SketchUp…my 2017 no longer works, so I am using the free online version.
All I want to do is draw a simple cube 33”wide x 37”Deep x 29” tall.
as I recall, i simply use the rectangle tool, click on the model space, let go of the mouse, and type my dimensions in open space, seperated by commas. However, nothing shows in the measurement box, and the cube is not drawn.
Is there a different way to inter exact dimensions in the web version?
Thanks for the help
You need to at least move the mouse in a direction after the initial click.
No, it’s the same as in SketchUp 2017.
Note that you first need to draw a rectangle and then push-pull to height.
