I’m having an interesting problem with SU 2014. I just upgraded from reliable SU V8 and I’m using a mac. I frequently use my SU plan view and export it as a DWG, which I then reimport into SU as a plan background to work over. This morning I exported a plan view, scale as 1:1, and when I imported into SU it was way out of scale. A surface that measures 14’-9" in SU has resulted in a DWG output that measures 177’-9" I’ve tried to export without the “full scale” checkbox checked, also reserved the V8 file as 2014, with the same result… mis-scaled DWG output. I also verified the DWG in Acad with similar results.
This is obviously a serious problem considering all the DWG output I create from SU for ACAD work.
Any suggestions or fixes would be most appreciated, thanks.
